Removes a virtual link.
router-identifier | Specifies the router ID of the other end of the link. |
area-identifier | Specifies an OSPF area. |
N/A.
None.
The following command deletes a virtual link:
configure ospf delete virtual-link 10.1.2.1 10.1.0.0
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
